I read a knife making book from the library that addressed this question quite well. The maker seemed to specialize in this type of knife and had several different blade shapes with zero bevel grinds. He recommended woodworking edges (as in bushcraft woodwork) have no secondary bevel, but for utility and hunting work, a small secondary bevel was preferred. Basically, if your uses damage a blade without a secondary bevel, either by excessive rolling, chipping, or other, a secondary edge is preferred. He said the secondary bevel shouldnt be more than 1/64" wide. So, if you have a knife with a knife with this kind of edge, and your uses dont damage it, I'd stick with it. If they do, or you want to cut down on sharpening time, then a small secondary bevel will strengthen the edge and allow quick touch up sharpenings between major metal removal sessions. I have only one knife like this, and it has a convex scandinavian grind instead of the usual flat grind. For the shop and kitchen work I did with it, this edge was adequate and did not show signs of damage after about a month. I did add a secondary bevel just to make sharpenings faster. My secondary bevel is very small, almost invisible without ideal lighting. It doesnt seem to reduce cutting ability, and I can get a razor edge in a few swipes of the 20 degree slots on the Sharpmaker.
