The general purpose scandi knives (from mora, hultafors and the likes) usually come with a secondary micro bevel, perhaps from a rubber wheel finish?
These knives see heavy use and then receive crude sharpening in the field with whatever is accessible in terms of sharpening medium. This could be a small pocket diamond stone with fine grit (in my case), it could be a generic stone (usually way to coarse and used dry), could be the underside of a porcelain coffee cup, top of car window, angle grinder, sand paper or another knife even... Either one you pick, or a good combo of the mentioned methods will result in a larger and larger secondary bevel which in time will morf to a convex scandi because of all the wobbly free-handed quick sharpening. With a thick and wobbly edge these knifes are not scary sharp on most days but they are usually not so bad either. Sharp enough to gut a fish with some work, cut down a twig or two, make some kindling, cut a rope, split a cardboard box, open up a paint can, where the heck is the flat screwdriver... Best do some quick resharpening.
Scandi zero grinds, made for finer woodworking, is a a whole other story. They come with a flat scandi zero grind. Perhaps there's a nano bevel from stropping but that's it. They are used and cared for by a craftsman who cares for them and has a a small arsenal of them. They can have less or more acute edge angles, all suited to their purpose. These are treasured tools, used for their purpose and kept sharp.
Somewhere in the background always lurking is the general purpose scandi though. There's usually more than one infact! It's there and it's ready. It's paint chipped handle and functional yet gruesome grind, ready for any task suited or not suited for a knife. Open up a sodapop, cut a radiator hose or deburr some spiral ventilation pipe with it's nasty spine.
Wonder if I can get this to stick to the furthest wall if I throw it real hard? Huh.. nah, dind't stick.
I have both types. I don't think there's a right and wrong when it comes to scandi zero grinds and scandi grinds with micro/secondary bevels. They do different things though. As a bush knife I like a secondary bevel or a slight convex though.
Found this one on a local classifieds. Could be had for $35 + shipping. If it could speak I think it would be worth it.
