- Nov 14, 2001
Hi all,
Here's a better picture and more info on Ed's san mai camp knife. PhilL took the picture for me and I think he did a great job, thanks! First the photo...
Ed patterned this knife as a competition blade but at 13 oz. it's quite a bit lighter than most. The weight makes it better suited as an all around camp knife but hampers it's ability to quickly cut through 2x4's during that portion of a competition. The blade is a little short of the 10" allowed, has a deep recurve, integral guard and sacrifices about 3/4 of an inch in order to accommodate a finger choil. The butt of the handle has a steep drop to allow the knife to be released with the wrist in stroke and not cantilever against the palm or butt of the hand. The false edge along the spine of the blade brings the weight in closer towards the cutting edge in order to resist rotational forces and keep the blade from twisting in your hand. The rubber handle is affixed using over a dozen pins made from o-ring material and are glued in place. There's also a metal fastener in the center of the handle in order to comply with competition mandates.
The blade consists of pin striped 1080-15N20 damascus over a 52100 core. The damascus was thermal cycled several times before being welded to the core. The finished billet was then thermal cycled 3 times in the forge then 3 times in the paragon oven. The piece was triple quenched and triple tempered. After the first two tempers it was soft back drawn into the low 50's Rockwell C scale. The edge is in the 60-61 range. The blade has been used in two competitions and performed well other than during the 2x4 cut.
Hopefully Ed will drop by to correct any mistakes or make any additions he deems necessary.
