- Oct 29, 2015
I’ll try to grind my next knife down to at least .01” to speed things along with the wicked edge. Hopefully I can do that and not mess with the temper.
Do you have a variable speed grinder? If you do try grinding down to around .01 or less with a 120 grit ceramic belt. With lower speed that should be easy enough to do. After that I slow down the belt and use a spray bottle with soapy water every few passes. Also add a little soap to your dunk bucket. This helps the water to sheet the surface better. I like to do my final grinds lengthwise on the platten. The water will run down to the tip and keep it cool as you clean up the grind lines. .007 to .002 or so is a great place to aim for on kitchen knives.I’m just scared to go any thinner. I’m pretty new to knife making and I’m afraid I’ll ruin the temper on the edge.
I hope I didn't give the impression that I was recommending edges that thick. I simply meant that for cutting hair on your arm thickness isn't as big of deal since it is the apex that catches the hair to cut it off. When cutting thicker things it isn't going to cut well even if the apex is sharp. I can sharpen a axe to shave with but I don't want to cut up dinner with anything that thick. I find that somewhere around a .003 to .005 edge thickness is not that hard to achieve. If someone is worried about over heating the edge they can thin it down into that range when hand sanding. Stacy has given good advice about how to make a high performance blade as well as how to get a good edge.I don't understand the thicknesses people are giving??
Hair shaving sharp is thin sharp. The edge should be below .01" before starting to sharpen it. I take it to near zero ( almost sharp) before sharpening. I doubt the edge is more than .003-.005 when I start to sharpen.
A .03" thickness is 1/32". There are knives made from sheet stock that thick.
Pressure is the key here. Let the machine do the work. Light pressure and take your time. I was burning my fingers on every pass until I reread some grinding advice threads and light pressure is really important.Yes I have a variable speed grinder. I’ll try that with the soapy water. The last knife I ground was a hollow grind I took to .03” and I burned all my finger tips trying to get it that far. Perhaps I should slow the belt down even more. I think I was running at 50% speed on that one.
