- Feb 18, 2016
Probably be best to have it in the muffle
This is my plan for my electrical sandpot Ht oven I work on .....That's not a bad idea. Also makes using the chamber for axe heads easier.
Are there PIDs that allow switching between two TCs, or do you need to install a DPST to do the switching manually? I agree with the response time bit, but after a calibration cycle at a specific temp, the PID should work near perfectly and run flat out until it gets close the the desired muffle temp. Unless I am missing something, the cal cycle should eliminate the overshoot.My reason for starting with a TC in the chamber was to get a better heating curve. If the TC was inside a steel muffle, it would take a long time for the PID to read any temperature increase/decrease. Coil firing swings could be large as the response time to high/low readings will be very slow. If you have only one in the muffle you would have to run the kiln for a good hour or so to get it equalized and steady at the target temp.
With a TC in the chamber and another in the muffle, once the entire chamber and muffle are stable at the target, switching to the muffle TC will provide an accurate reading of the blade temp to the PID.
Today I was repair some vaccum pump from one friend and I thought on this thread ....So , why you don t make that tube closed chamber and use vaccum or argon gas inside ?I wasn't looking but saw it on the local craigslist and the price was right. 7200 watt and 22.25 x 17 inside with ramp control, 6 program slots and 2300f. Paid $500. Seller claimed she fired it only 3 times and it looks it.
So since it's vertical, my plan is to cut a hole in the top, drop a stainless tube in, and connect argon to the tube. I'll use wool to cover the tube. Tube to baffle from radiant heat spikes, and reduce gas volume required.
View attachment 944249 View attachment 944250 View attachment 944251
