Hello all,
After extensive use of the search function I am unable to find a definitive answer, hence my post.
I've read that due to the shroud clearance issue on the Craftsman 2x42, you cannot use Scotch Brite belts. I've also read that you can cut portions of the shroud off in order to allow enough clearance to run Scotch Brite belts. I would rather avoid doing that if possible.
My questions are as follows:
-Do Scotch Brite belts come in varying thicknesses? Are some thicker than others? Can I run thinner ones in my Craftsman 2x42 without any modifications (if they exist)?
Thanks,
Matt Harmon
Thanks,
Matt Harmon
