Medium is super agressive from what I Have seen.
Shoot for fine or very fine. But this depends on the finish you want.
Silicon carbide works best for steel.
They gave me the same advise. So far I have only used the maroon dry (as once done with wd40 you can’t go back). I’m reasonably satisfied with the look ... but then again, as I pretty much only make kitchen knives, I am actually concerned about not having *too smooth* a finish (to reduce cut food sticking to the surface...)I was given a tip from Pops on these belts.
Grind to a 220 finish, then use the maroon with wd40 then finish with dry blue. I have not tried it yet.
I just bought the brown course and a extra course from tru grit. The extra course is fantastic for removing deep ceramic belt scratches. You can then go to a 220 and follow it up with something finer. It's worth a try.Allthough I maybe don't see myself using the maroon for end finishing, I think it may have a place for removing/blending lower grit scratches here and there.
Also just got cork belts in 400 and 600 grit. I am a dedicated non-hand-sander, so excited to try these too.
i think the blue belt leaves a nice finish. i dont think they come on ao or sc though.
I use the maroon and fine depending...
This is z wear with 60 micron lengthwise scratches and then the blue fine belt on my 4x36
I put a leather pad on the platen underneath... not sure that it does anything
It is without a few more hours...z-wear is the worst for getting a clean finish on. Other high alloy steels finish better. Frustrating. Your finish is as good as it gets.
