- Nov 27, 2013
So I'm just finishing up a Gyuto and was thinking about putting a satin finish on it. It's a full flat grind and has the little curve on the flats that goes up to the spine at the top of the plunge. I was thinking if I used a scotchbrite belt to hit the entire bevel then it might wash that out. I was thinking that I could use the scotchbrite belt and then come back over and hand sand the flats. The issue is that little curve doesn't have much material on it and a scotchbrite belt might even knock it off, leaving me with a grind that ends at the spine(not just below like it should be).
Any ideas?
Any ideas?
