Scotchbrite questions
I am working on a knife right now. I have hand sanded to 400 grit so far and I am planning on doing a scotchbrite belt finish. I have a medium and a fine belt. I have a couple of questions before I continue though.
Is 400 grit high enough to sand to before sb?
Is it ok to hand sand horizontally then use the sb vertically?
Should I use the sb before ht as well as after?
Thank you
Thank you
400 is high enough.
You can sand horizontally then use the SB belt vertically without issue.
I don't see much point in using the SB belt pre HT, especially if you need the thin out the blade post HT.
