I agree that a blade should not be kept wrapped. I've even tried to heavily oil a blade before wrapping it and if left on for a couple days, chances are that I'll find a rust spot or two. Now, I remove any wrap before the day is over and oil the blade immediately. I find that 3 in One is one of the better rust preventing oils. WD-40 seems to prevent rust, but eventually attracts moisture... Kind of a mixed bag for me. I also like the rust prevention properties of Ballitstol, but I cant stand the smell of it. Smells like my grandpa's old tackle box.
What you’re wrapping the blade with makes a big deal too. I never put any adhesive directly on the blade. That goes for any type of tape. The layer of printer paper has made a big difference for me. I usually just use two sheets of the paper and saturate them with either oil or wd-40. It’s weird that you say wd-40 “attracts” water, since the “wd” stands for water displacement. I’m not doubting you of course, it’s just weird that you’ve had that happen. Anyway, once I lube up the blade and wrap in th oil saturated printer paper(you don’t need to put it on every inch of the paper, just the area that will be in direct contact with the blade. Then wrap with electrical tape. There’s some elasticity in the electrical tape, and that’s what you’re relying on to hold the paper on. Because the electrical tape adhesive won’t stick to the oil saturated paper. But once you go around a couple times, it will stick to the back of itself. At this point you should be gtg. Sometimes I’ll wrap a piece of electrical tape down around the ricasso to keep the wrap from slipping off the tip
WD- 40 is actually good stuff, but has kinda got a bad rap since the interwebs came around. Probably on gun forums & probably cause it's sold everywhere. It's basically mineral oil & solvent. Once the solvent evaporates all that's left is oil. It does not "attract water". lol
I guess I can see that, but it depends on how saturated with WD-40 the paper towel is.WD-40 on a paper towel that has had the solevant dry up in, doesn't have enough oil to prevent the paper towel from absorbing moisture like it normally would. I'm not claiming that WD-40 itself attracts water, just that a paper towel wrapped blade that has had WD-40 applied to it will eventually rust because the paper towel will collect moisture.
