Screws into G-10??
Is G10 strong enough to hold screws in place?
How does it compare to aluminum?
Is chicken a vegetable?
it can be done but if you over tighten them they'll strip out before you realize it.I'd advise using some sort of nut on the opposite end to secure screws.Early Benchmades were threaded into G10 but all the current knives use a small nut. I take their hint.
George,
What size screws do you use and how far are they threaded into the g10???
obviously..part of the solution is how thick the g10 is....thicker is better...smaller finer thread is better too (more threads per inch...like 0-80 as compared to 2-56..the second number is threads per inch...i always thread the g10 AND the ti liner when i put clips on knives...works very well....if you do it right there is no problem whatsoever.. make sure you torque them down well and grind them perfectly flat on the inside..i always use three screws...usually 2-56.
http://www.mayoknives.com
