'SEAL' linerlock/hamon (SOLD)
BogdanS
Feedback: +54 / =0 / -0
Hello my dear friends,
Today, with God's good will i have the pleasure to present you a new folding knife based on the 'Police' frame - 'SEAL'
After a lot of work and investment we now have all means to create knives on the highest standards. The new 'brand' under which all our knives will be sold is called 'Microlab' for the sole reason that this is indeed where they come from. In order to cut costs with space and use the money into precision equipment we went for a cubicle small shop with a separate dust room that allow us for a lab like environment to work in :)
In the 'dust room' we have the 'angry beavers' as i call the bandsaw and the grinder while 'the lab' offers a dust and dirt free environment for clean and precise work.
Autocad designed blades are transposed on the ground flat steel stock and cut into shape using an industrial grade metal bandsaw that together with always fresh bands assure minimal steel structure distortion on the cut. All grinding is performed on an 'in house' designed and manufactured grinder with micro adjusted and digitally controlled angles using Austrian made Sola equipment and a perfect flat ceramic glass platen for the best results.
The HT is performed in a laboratory calibrated kiln with lab precision thermocouple and electronic control following strictly manufacturers HT diagrams from renowned EU steel manufacturers like Sandvik and Uddeholm. Tempering is done in an oven controlled through high end Digitron temperature control equipment. After the HT the blades are tumble finished in order to smoothen all sharp edges.
Handle materials are always of top quality, industrially high density micarta, high end carbon fiber composites and the list goes on; the scales are then contoured on the mill and finally hand finished for a nice fit and finish. All guiding holes are drilled on a precision mini mill to assure a perfect perpendicular hole. They are after that reamed to final quotes for very tight tolerances. Taking all these into account we use no glue into applying the scales to the tang but on request marine grade epoxy can be used. The screws all all tightened to optimal manufacturer recommendation torque (at 0.75 nm) using homologated Wiha torque screwdrivers, for best results while the pivot pin is hand tuned for optimum action.
The knives comes super sharp right out of the box and ready for use for the best user experience.
The blade is centered and has a nice smooth but firm action due to the phosphorous bronze machined washers. We make the washers on a cnc precision lathe as the micro grooved surface left behind has the overall surface wider while the contact surface is kept to a minimum, the tang rotating only on groove peaks.
All parts but the screws and washers are handmade in our shop for a one of a kind product.
The specs are as follows:
- 26c3 high carbon steel 0.93" thick - clay hardened with a nice hamon (65 HRC)
- full flat grind
- acid etch finish
- phosphorous bronze washers cnc machined
- custom turned blued steel thumbstud
- lightweight heat treated stainless steel liners
- overall length 7.5" with a blade length of 3.15"
- high density black linen micarta
- 'goblin green' anodized aluminum washers and black steel screws & brass pivots
The price for this knife is SOLD
All and only the best, God bless,
Bogdan
Your new place sounds great, I am happy you have a high tech environment to create your wonderful knives.
Cheers! That new piece is a winner.
mycough mycough - thank you very much my dear friend for the warm thoughts and kind appreciation!
Bogdan
Here we go with a short vid of it's action ;)
All the best, God bless,
Bogdan
Hey Bogdan,
I hope all is well.
I cannot pass up a custom folder from you at the flash sale price. If it is still available, I will take it.
I will send you an email shortly as well.
Thanks
Hey Bogdan,
I hope all is well.
Thanks
A BIG thank you my dear friend for your generous and continous support - may this knife serve you well and make you proud! ;)
Bogdan
