Search & Rescue Knife Review
Recently Stomper (John) from JK Handmade Knives held a contest for his second anniversary in the custom knife making business. John wanted all forum members from Blade Forums to submit designs for his second anniversary knife. I submitted a design I had in mind for about a year now on what I felt would be a good knife for Search & Rescue operations or hunting/woodland adventures. I’ve been involved in Law Enforcement S&R (my career) and before that with my local fire department for 18 years now. Like many of you I grew up in the woods and love hiking and hunting. I asked John to make this knife for me and he didn’t disappoint. He nailed it as usual.
My design involved a knife with a 4” blade and a 4 1/2 “ handle. I also wanted to have a backup single row saw tooth back in case it was needed. I wanted a very sharp point on this knife and John did his usual EXTREME sharp blade on his knife. Damn sharp!
Notice under the makers stamp I also had John put an integral fire steel striker. I never liked the idea of trying to use the "back" of the blade or definitely not the blade itself.
The single row saw teeth zipped right through wood I grabbed from my back yard as a test today. Think melted butter.
I also had John drill a 3/16 x 2.5” hole in the handle (think Swiss Army Knife toothpick) for a fire steel to be slipped in.
I also wanted a double lanyard layout in case the knife had to be lashed to a stick for a spear or similar setup.
Another thing I asked for was a kydex sheath that could be utilized horizontal or vertical carry based on the equipment I had at any given moment.
The handles are strong black canvas micarta and the knife is solid 01 steel that is heat treated to a level of strength that is impressive. It fits your hand perfectly.
Overall this is a solid package that John put together. It’s rare to be able to draw up a design you have in your head and have someone that can make it a reality exactly the way you meant. John did this and I think this knife is perfect for wood use especially for Search & Rescue.
If you get a chance stop by his website at http://www.jkhandmadeknives.com or his forum over at bladeforums.com. This guy is damn good and can make your design into a reality. He also has a nice line up of knives at very reasonable prices.
I looked around for years and like many others here purchased knifes from SOG, Buck, Case, etc. but when you have a knife made to your specs….there’s NOTHING like that! WOOSHA!
I'll be posting updates on this knife as I use it. Monday I'm heading out on a hike and I'll be sure to update.
Stay Safe!
As much as I don't like things on my spine, I think this knife looks really good. John really executed this one well. :thumbup:
Sweet custom! I like the firesteel notch. It looks handy to use and should be pretty easy to keep square. Is there any retention method of holding the firesteel in the handle?
Your sheath looks a lot like the one Bill Siegle made for me for my SAR-4. I found that the large pouch from Countycomm works pretty good attached to the sheath.
Yeah he nailed this one. :thumbup::thumbup::thumbup:
The fire steel slips into the channel which is 2" long. It holds a 3/16 x 2.5" fire steel so 1/2" sticks out to grab onto a pull out. Good solid hold on her.
I love this.
very nice blade. i love the survival/ usability aspect of it. what a great all around tool for you. well done and jk makes some great stuff from what i can tell. can't wait to get my custom from him
wow.. it looks like you put a lot of thought into the functionality of the knife. i really like the integral fire steel striker idea and the place to put the fire steel. awesome stuff!
That is a great looking knife. I love the fire steel striker idea.
I like the idea of carrying the fire steel in the handle to, but couldn't you have drilled the hole in the back of the handle and through the lanyard hole, and then run the 550 lanyard through the hole and block the fire steel from possible coming out? I mean after the SS tubing is epoxied in place, drill a hole slightly larger than the fire steel in the back of the handle and deep enough so it clears the hole to run 550 through and your 550 is what retains the fire steel no matter what size it is. Since the hole is a little larger, the fire steel will just fall out of the hole when the 550 is removed.
I'm just thinking that as soon as you start using the fire steel, and it gets smaller you have lost your friction fit and it will fall out.
I thought about that, but these fire steels are so cheap once I even see any loose issues I throw a new one in. They are standard 3/16 x 2.5"
That looks great buddy, John did an awesome job of bringing the design to life as usual !!!
I do think MrPan might be onto something with the idea of going through the lanyard tube, this may mean that it would need a slightly larger diameter lanyard tube but I'm sure it would work.
Okay, that turned out much better than I was expecting! I love the idea of a saw on a knife but haven't found one that I'm satisfied with. Do you feel this will hold up and how hard will it be to sharpen? Are there any worries of your thumb sliding up onto the saw? I think I would prefer a thumb ramp or at least jimping before the saw.
The firesteel idea is a good one, but I definitely like the idea of the lanyard holding it in place, so there's no fear of losing it.
John executed a really good design. Nice job!
The more I look at this, the more I like it.
If it was me Pit, I would just leave the SS tube out completely and just have a lanyard hole and another for the fire steel. Makes life a lot easier for the maker.
If you have to have the SS tube, then I would make sure I stuck a tight fitting dowel rod inside the tube before drilling. That way you can support the tube wall and there is no chance of the drill bit catching and making a mess inside the tube when it's coming through the tube wall. Did I explain that so it makes sense?
Thats a useful blade. I'm a big fan of saw backs. They will go threw small stuff real quick.
Only thing I'd change would be moving the teeth forward away from the thumb rest area.
Great design MrBear and Nice work Stomper!
Yeah, to hell with sawbacks. :D Very cool otherwise. How is the firesteel kept in place? How's it removed?
