trimcut123
BANNED
- Feb 15, 2007
I just hope its fixed when it comes back......
I wonder if the "issue" is with the way the CRs are heat treated? There are tons of S30v blades out there by other companies. They aren't all chipping.
Re: chipping
I suspect that the extreme wear resistance of S30V can cause problems with fine edges and power sharpening. I'll bet they get too hot and affect the heat treatment on the very edge--maybe a mm or so. This may happen with worn belts, or just a bit of inattention at the critical time.
A re-profile and sharpen seems to be enough to stop the chipping on most blades.
Hope you get you problem sorted.
Greg
All my Striders are either BG or ATS. It would be interesting to compare the wear characteristics of their S30V with CRK's, given that Bos does the Striders.
I wonder what Bos does different, if anything.
It could be down to market forces. Buyer hears S30V is better then what was before so high end companies switch to keep the trend going.we see a pretty big shift in the direction of S30V... and I guess CPM in general. There's got to be a substantial amount of thought behind that.
From the Strider knives I've seen I would think they make up for any weakness in the steel by having a lot of it there.
Thanks for the constructive criticism guys.....![]()
speaking of constructive criticism... have you ever stepped back and taken a look at any single one of the MANY posts youve made on this forum?i cant even concentrate on what you're posts are saying anymore because of the extreme over-use of ellipsis in EVERY one of your posts after EVERY sentence. try replacing 99% of those ellipses with periods. its just as annoying as people who put 30 question marks or exclamation points after a sentence instead of 1!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
</rant>
</rant>
Frasier? Frasier Crane? Is that you?
Since we're on the topic of punctuation, let's break down your post a little bit:
youve made should be you've made
you're posts should be your posts
over-use should be overused or overly used
ellipses should be ellipsis (you got it right once but screwed the pooch on the other one. I never would have picked it up had you been consistently wrong)
its should be it's or it is
Then there are the missed capitalizations at the beginning of sentences, but no reason to go on.
Have a great day!
