- Dec 30, 2013
So today I was doing some work outside, and I needed to cut some tar paper. I decided that this would be a good task for my Large 21. I measured the tar paper, placed the area that needed to be cut, on a piece of plywood. I made sure there was no nails or anything in the wood before cutting on it. I cut 3 lengths of tar paper, and went inside. When I got inside, I cleaned the tar residue off my Sebenza, and that when I noticed the edge had deformed at the spot that did the cutting.
I when and gave it a few swipes on the .6 micron ceramic, and then some passes on the .5 micron strop. Here's what it looks like now.
I wasn't applying any unnecessary force on the blade, nor was I torquing the blade side ways. If you look carefully it's almost as if the apex of the edge has a slight flat spot. This is the second time something like this has happened however. I used to work in a warehouse, and part of my job involved cutting cardboard boxes. After a few weeks of work, I ended up with a Large roll in my blade. So much so, that I had to take the knife to a store to have it re-profiled. The roll ran roughly 3/4" to 1" of the blade, and was located right near the same spot this most recent deformation occurred. The first roll occurred with the factory convex edge, and the second deformation occurred with a 40 Degree inclusive bevel with a 34 Degree micro-bevel.
I am not trying to bash CRK, I love their knives. I just want to know why this is happening to my Sebenza doing what I consider to be light cutting tasks.
Lastly, my Sebenza is a Large 21. Birthday: November 27, 2013. In case anyone else has had similar issues with Sebenzas from this time of production.
EDIT: Upon further examination, I think Unit may have been correct, I think the abrasiveness of the tar paper wore a slight flat spot on the edge. As if I was cutting sand paper.
