- May 1, 2016
Ultimately, you're asking but you think this is a problem. If you think it is a problem, you should absolutely send it back to CRK, IMHO. There are limits to what we can say from a video without being able to inspect a knife, and the Maker is best qualified to determine what is going on and address it accordingly.
That said, how much pressure are you putting on the spine? It looks to be quite a bit, but again videos can be deceiving. To me, that determines if there is an issue. If this is an amount of force that you could apply with your thumb when using the knife or if the knife should slip during normal usage and contact a surface with the spine, it's a very big issue and the knife needs immediate service. If you are using a lot of your body weight to place tremendous force on the knife, it's not. If I was going to be performing work that would potentially place tremendous force on the spine of the knife, I'd use my ESEE 6 or another fixed blade with thick and soft steel.
Further, your pivot appears to potentially be loose, and my first hand experimentation out of curiously has found that this can and generally will cause both liner locks and frame locks (with and without pivot bushings) to 'fail' (if you consider such usage to constitute a failure) in this scenario with much less downward pressure than if the pivot is tighter.
In sum, I think you should send the knife to CRK.
Just want to assure everyone the pivot is definitely not loose. Everything is very tight, no play and blade doesn't drop freely, there is no greese/lube whatsoever.
I am pushing with weight I guess but not leaning on it. My other knives I have all have been subject to this and they pass because they don't have the issue presented. I am offering you a quick easy test, just put the lockbar at the end and see if it's prone to slipping and also facilitating a discussion here on whether it should even be acceptable or not. To some people here, this is completely fine. That's why there is a poll, you can all see for yourselves.
I used to work as a welder/fabricator and when doing installations found myself in a lot of crowded spaces on ladders etc. This is something people here like to bring up, when they are on a ladder they like to be able to have a one hand open operation with their folder. So no fixed blade. This folder we are talking about, "the original hard use knife" called worker, implies being able to be utilized in these kinds of settings. Well shit can happen and your ladder can wobble a bit while you have the knife out. You might flail your arm to regain balance and tap the spine on this same ladder or something else. Something can fall when you have the knife out. I am done fantasizing...
I feel it's a flaw in my knife and it's a forum where we discuss things and I think with some folks attitudes this is something that could have been overlooked for a while as people are quick to brush it under the rug of not intended use and not look at it as a possible design flaw. Basically brushing all of this off and sending me to CRK or switch to other brands. I like this brand and want it to improve. Spyderco for example listens to their customers if customers think there is a problem.
