My 25 has seen "real work" as well. It has a definite track to where the ball stops, and what you might call a slight divot. Nothing pronounced like that.
My best guess is the thicker-than-normal (or so it appears to me) aftermarket scale is preventing the pivot from screwing in all the way, or maybe from being held firmly. Also, the factory bevel on the back of the pivot screw precisely matched the factory bevel on the slab. I could see that if there is any mismatch, it could introduce play in this assembly. This play may be almost unnoticeable, but create a situation that as the knife is opened, the ball sips off the end of the tang, takes up the slight slack in the assembly, than slams back into the tang, creating the divot.
I would sand the divot flush, with very fine sandpaper, and swap out the CF scale and see if the problem comes back. Or just live with it. Might be the price you pay if you like that scale.
Just my two bits.
Sanding the lockface of the blade is a horrible, horrible idea. Any material removed is going to greatly affect the lockup, and any change in angle would wreak havoc with lockup, too. CRK uses a machine to cut the blades lockface to an exact fit for every single folder that leaves the shop. The difference between good lockup and bad lockup is like a couple of thousandths. Sanding it will make it lock up deeper, and might cause worse stick, or even lock slip.
The only course of action is to send it in.
And take that damn scale off, LOL. It's too thick, it looks goofy as hell, and there is no way that it is built to CRK (.0005) specs.
I was only suggesting to sand the ridge of the divot away, not the entire face.
I was only suggesting to sand the ridge of the divot away, not the entire face, but whatever. In the Blade HQ video you can see the guy free-hand tweaking the lack-face using a brown Spyderco rod. There seems to be some forgiveness in this area if you are careful and go slow. In fact a spyderco rod might be the right tool to smooth that divot out. I wouldn't worry about doing that myself, but if you want to send it in, go for it.
He isn't tweaking the angle, he is cleaning up any burrs around the edges left by the machine that cuts the angle.
And HE knows what he is doing.
Oh and to answer some of the realistic questions: no, there's no blade play in any direction.
Do you think it has anything to do with using your CRK without the rear handle screw on the presentation side?
Again, I am not suggesting anyone tweak any angles, or remove the surface of the lock-face , just use the rod or sandpaper to take the smallest of amounts off the edge of that divot, just like the fellow at CRK is doing in the video with cleaning up the burs.
I don't think it's rocket science, nor do I think CRK is going to wave a magic wand the average joe doesn't possess, but that's just my opinion, and the way I personally look at problems like this. I don't suggest that anyone subscribe to my point of view, but do encourage all folk to realize we often have the capabilities to solve simple problems for ourselves if we just go slow and take our time, and think about what we are doing, and the nature of the issue. It's what separates us from Gorillas after all, and what made Chris Reeve decide he was going to make a knife in the first place. But, like most said, it's safer to send it in and have them do it for you.
