- Apr 2, 2012
Just want to start out by saying I like both my Sebenzas very much and intend to keep them. This is not meant to be a CRK whine and cheese thread, but rather some info to the CRK community on possible causes to any blade centering issue found on a Sebenza. It certainly seems my experience is not unique, so this may apply to other blades as well.
Short version of the paragraphs below - the blades are not straight on either of my Sebbies. Read below for how I got to that conclusion.
Having read a few threads recently, a few folks commented about their new Sebbie's blade being off-center. I own two Sebenzas, both from April 2012. My large Insingo was bought new from a dealer, while the small micarta Insingo was purchased LNIB from a BF member. Both knives were received with blades biased towards the lock bar. Both have been cleaned and lubed a few times now, so things are better broken in. By following the published CRK procedure for cleaning and reassembly, I was unable to produce any visually noticeable difference in centering. In a way, this tells me that the tolerances of the assembled are such that reassembly is a very repeatable process.
I used a Mitutoyo digital caliper for all measurements, model 500-192-20. A fine knife deserves a fine tool to be measured with
I measured the Ti scale spacing to be 0.1530". This puts a centered blade at 0.0765" from one of the scales. On my Sebbie, my blade tip measured 0.0650" from the lock side. This puts the blade at 0.0115" off center. Visually, the blade looks center from the spine side of the knife, but looks slightly off when looked at from the other side. Can't figure out why, but that's what I see, vs what I measured. For reference, the plastic card stock used for credit and debit cards is 0.030". So, my large Sebbie is off center by 1/3 the thickness of a credit card.
On my small Sebenza, my scale spacing was measured to be 0.1440". That puts a centered blade at 0.072" from the scale. My small Sebbie measured only 0.0555" from the lock bar side, or 0.0165" off center. To me, that extra few thousands is far more visually obvious on the knife.
Ok, so my blades are off center. Next thing was to find out why. I was able to devise a simple fixture where i could hold the blade pivot area on a flat surface and scratch a block of aluminum with the tip of the blade. I was then able to flip the blade and mark the aluminum block again. A "perfect" blade should produce the scratch in the same spot from either side. In the case of both my blades, that didn't happen. The better centered large blade produced scratches about 10 thousands apart, while the small blade (the worse one) was about 20 thousands apart. The absolute values of these measurements may not be right on, but visually, there was a clear difference in the scratch spacing between the two blades.
Next steps were to take a straight edge to the flat portions of the blade and see if I can find any bowing. I found that on my small Sebbie blade I saw lots more light in the gap on one side of the blade than the other.
To me, the amazing thing is how consistently my Sebbies go together. While they're not perfect in every way, the tolerances are most definitely better than any knife i've ever owned. It appears that with some Sebenzas, the blades themselves are not perfectly straight. This would also imply that given proper assembly, centering the blade will not be normally possible. If the scales are straight and the washers uniformly thick, there's no reason why a straight blade would not be centered. A slightly bowed blade however does not stand a chance. That seems to be the case with my two Sebbies.
I'm debating if I want to send them in. I like using them both and don't really want to let them out of my sight. Anywho, just a bit of info for fellow CRK owners. I'm not saying all blade centering issues mean a bent blade, but it seems to be the case for me.
