Others have 'tuned' their Sebs to thumb-flick smoothly and consistently by carefully polishing the washers--just to the point where the blade drops freely when the lock is disengaged. I typically don't flick my one-handers, so I haven't felt the need to do this to my Sebs. Might be an option for you though, OP!
Good luck!
-Brett
I would strongly suggest not doing this. Polishing the washers will not make the blade fall freely. The only way to make that happen is to tune the pressure of the lockbar (i.e. make it weaker).
If you release the lock and hold it, the blade will already fall freely. It's a common misconception that bearings or polished washers make a knife "fall shut freely", but in reality it's just the pressure of the lockbar pushing on the blade tang.
Removing material from the washers (polishing) will just throw off your tolerances and possibly off-center the blade or cause blade-play.
Sebenza isn't a flipper, no flipper on it. It's a one hand opener, you could wrist flick it, but it ain't gonna flip.
I'm pretty sure OP is talking about how the Sebenza doesn't flip consistently when thumb-flicking it.
In that case, it's because the Sebenza doesn't have a very strong detent that allows you to build pressure up. In other words, it won't give you that "pop" when flicking it open.
Hand polishing the washers is actually done at CRK to tune the action. https://www.youtube.com/watch?v=Nj6p8p6vfZQ (as seen around 7:05.)
I have a small Insingo and a small Box Elder 21 and can flip both easily with the back of my thumbnail with no wrist at all.
Neither has a strong detent.
It's very easy to do, I just choose not to most of the time.
Edit: I guess that's "flicking" and not "flipping," but maybe that's just semantics.
Yes, and so they usually come from the factory correctly tuned: so that the lockbar is the main force keeping the blade from swinging (nearly) free. Further polishing of those washers will not reduce the pressure that the lockbar applies, so isn't a reliable way to make the blade swing faster.
