Sebenza integral lock
Just wondering, what is this integral lock -system like. Only thing I know about this is from the text on KnifeCenter's Sebenza-page and it didn't say so much to me (it's me, not the text). I would appreciate it if somebody explained it thoroughly to me (or even better, if there's a picture of the engaged lock somewhere...). What about the can't-remember-its-name from Benchmade, does it have a same kind of integral lock?
Jani
Jani; the Sebenza lock is simple to describe: imagine not just the thin Ti liner lock sliding in behind the tang when the blade is locked open, but the entire top half of the scale on that side.
That is how it works. The Ti scale is slotted horizontally so the top can act as a blade lock, while the bottom half of the thick Ti scale maintains structural integrity.
You have about 1/8" of Ti behind the blade, and squeezing the scales moves the locking part of the scale in behind the tang more securely. Hope this helps, Walter Welch
Hi Jani!
Maybe this picture will illustrate what Walt and Senator are trying to explain...
p.s. this is not a Sebenza it's a Vector : )
Joel
Actually, what make the lock stronger is that when you are gripping tight the handle, you are also re-enforcing the lock. A few of other brands also have the same mechanism but under different name. Like "Frame lock" in the KISS and "Monolock" in the soon-to-be released BM Pinnacle. There may be more...
The idea is good except that one will be limit to use hard material like Titanium for the handles cum lock.
My 2 cents.
Andy
Here is what they are talking about.
The following info is from Chris's site and tell more about the man behind the knife.
What sets Chris Reeve's knives apart from most others is dedication to quality, performance and value for money. These knives are working tools of supreme strength and durability. They have been tested extensively and are the result of unique design, top quality steel, sophisticated machining, hand craftsmanship and good old-fashioned hard work! Chris Reeve Knives is a very small company manned by a group of hard workers who strive to produce the very best knives which will work exceptionally at an affordable price.
Chris was trained and worked for 13 years as a Tool and Die Maker and, although his interest in knives has taken him into a somewhat different career, the knowledge gained from his training has proven invaluable in producing knives which are recognized world-wide as the best in their field. He has been making knives since 1975, and as a full time maker since 1984. Born and raised in Durban, South Africa, Chris moved to the United States in 1989 where he has been able to access the multitude of information and technology available in this country. Much of this technology is now being seen in the methods he is using to produce both his fixed blades and folding knives.
All of the knives shown in this web site are a combination of modern computer controlled technology and good, old fashioned hard work. Some of the initial stages of handles and blades are prepared on large and expensive machinery. The one piece work is done for us by an excellent machine shop and all of the work for the folders is done in-house. All blades are ground by hand and all polishing is done with that special ingredient "elbow grease"! Heat treatment is done in house under Chris' very critical scrutiny and blades are random tested on the hardness tester seen with Chris in the photo above. Folders are assembled with total dedication so that the fit of pivot pins and bearings is within the most exacting standards.
America's Best Cutlery - Direct!
1-800-956-4652
Mon-Fri 9-6 Est
www.abc-direct.com
