You can mix Nano Oil with any other lubricant including itself (different weights).
I don't know if there is any one Nano Oil close to lithium grease. The owner reccomends warming the 85 weight before you try to use it. So, I would assume it is much thicker than lithium grease. The 5 and 10 weights are much lighter. You would probably need to buy a heavy weight and a lighter weight and mix them to get something close.
Isn't frog lube food safe too? I need to grab some if so.The white lithium grease is a good product. However, I recently have been converted to using Frog Lube on all my firearms and folders. I'll never use anything else now. Stuff is amazing.
