I always keep the shinny worn side on the tang. It has worn that way next to the tang and I keep it that way. If you switch, it will not be as smooth as "marthinas" stated. But to answer your question, not it really doesnt matter.
My washers touching the scale are more shiny then that touching the knife. I will see if I can get photos in the near future. Will be interested in hearing your opinion. I realised something else through the year of constant edc and sometime dissemble of the knife that the blade becomes 'polished' and the stone wash becomes like a mirror under the washers. Think its kinda cool. Like hidden user marks.![]()
When I got my first sebenza and took it apart, I read where people stated the washers had to go back on the way they came off because the knife wore them that way !!! Does this really hold water, probably not, but I have found myself doing it that way for reasons I think make sense. When I clean my washers, I lay them flat down on a papertowel and rub them back and forth keeping them perfectly flat all the while. This cleans them very well removing all the dirt, lint, corosion form the bronze, etc. One side is always dull and gritty(scale side), while the other side is always polished from the blade tang(tang side). I personally like to put the gritty side against the slabs as I feel the grittiness helps hold the washer to the scales better. The other polished side ( the side with the circular rings from rubbing against the tang ) remain against the blade as I feel they have worn that way. ...... This is stricely a personal preference as it has worked great for me over the couple years I have had sebenzas and is what I practice.
Quick question: When lining up the hole in the tang with the hole in the scales to insert the pivot pin, it takes me literally forever. I look at it under light and it looks lined up but then the pin won't go through. Does anyone have any methods or tricks for doing this that could reduce that time?
I use Only: "Chris Reeve Knives Fluorinated Grease. Specially formulated for use on all high friction areas of precision folding knives and guns, i.e., pivot bearings, locking bars and slides. Comes with rotating cap to seal tube and prevent leakage."![]()
I use BreakFree CLP as I have a bunch of it because I use it on all my guns. I was actually surprised how well it worked because it is lightweight and other lightweight oils I tried were not the greatest and I thought I might have to spring for the CRK grease.
