My large Sebenza action is smooth (as butter) and firm (not tight). I have several knives that open 'more freely' so they appear more smooth but they are not (e.g. Benchmade, Microtech). My Strider SnG is quite smooth but also firmer than my large Sebbie. My Strider AR is also quite smooth but also more freely opening than the Sebbie (due to the bulk of the blade, positioning of the stud, and the liner relief/curve I can get excellent purchase on the blade and open it real fast).
Let's try to define smooth here guys. Can a folder's action be "smooth" AND not "freely opening"? What do you mean precisely by these terms? If you have ever handled a folder with ball bearings like a Larry Chew or a TiNives, those ARE what I would call incredibly smooth (very little resistant in the action, as if on air).
I'm sure many of you have experienced the looser action on plain jane production folders (like say, an AFCK) wherein the action becomes particularly more free moving if you signficantly loosen the pivot screw, and becomes less so if you tighten the screw. Clearly, this is due to less frictional force because the handle slabs aren't clamping down on the pivot assembly as much. I would call the looser, more freely flowing action "smooth" and the tighter action "not smooth".
Shouldn't a high-end folder, such as a Sebenza, have action as freely moving as when you overly loosen a plain jane production folder, yet still be completely free of play? It seems to me that Sebenzas' pivot assemblies are "clamped" too tightly.
If the Sebenza is supposed to have very high tolerances, shouldn't the assembly be made in such a way that the parts fit exactly together, with no play, yet don't need to have (barely) any force to hold it together? It would seem to me such a situation would produce, what I would call, a very smooth action.
To illustrate what I mean, think of the blade tang, bushing, washers, and handle slabs as a sandwhich of flat metal plates. If these metal plates surfaces are TRUE (i.e. precisely flat) and mate within high tolerances, then if you were to stack them on top of each other, there should be NO space between them (i.e. no play). You wouldn't need to push down on them (hardly) with your hand (i.e. clamp them with a pivot screw very hard).
But this is not my experience with (several) Sebenzas. If you screw down the pivot EXACTLY to the point where there is no play (i.e. you are now exerting the minimum clamping force required), then the action is still NOT what I would call free flowing, compared to other folders I have handled (that had NO play). Clearly, the pivot assembly (blade, washers, et al) together are slightly too "thick" for the space between the handle slabs.
Anyway, that's my take on things.
