Well, i have a love-hate thing for Striders, love the knives, hate that their QC isnt what it could and should be. However, i do think its getting better, the black SnGs i examined seemed better made than the previous 2 generations, and also, the locks on the SnG are generally fitted tight initially, what this means is, they only barely engage the blade tang when new, and as you cycle the knife, it wears in and the lock begins to creep further into engagement, ultimately, engaging properly. This issue was discussed on the old BF Strider forum in detail and Mick S said the SnG needs to be broken in with a few hundred cycles before the lock will engage properly. I honestly thought at the time it sounded like a BS excuse for bad QC, however, i have to say, it turned out to be true on an SnG i had at the time, initially, it barely engaged the blade, i thought it was defective, but after repeated cycling, it ended up with pretty much perfect engagement. If you examine locks from guys like Mayo and JW Smith, my heros when it comes to perfect locks, they too start the lock out very far to the left, barely engaging the tang, with use, the lock seats itself and ends up with perfect engagement.
The clip is tight, but some people like that, and, its very easy to simply remove it (one screw) and bend it to make it a little less stiff.
Also, keep in mind, CR has had many years to perfect the Sebenza design, the SnG folders are still relatively new for Strider, the AR is their original folder and i do think the locks on them are generally better fitted than on the SnG's, so, it may just be a learning curve and again, the current SnG seems to be better made, maybe the 4th version will be Sebenza-like, who knows?
But yes, if you are used to the truly world-class fit and finish of the Sebenza, the SnG will seem a little crude at first, but it grows on you.
