Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Well, yes .. and no.I do not understand . . . . IF the bevel is a single bevel to zero edge then that is chisel grind , right ? If you sharpen that bevel from both side it is no more chisel grind .................it become classic V grind ???
True, to the purist it no longer has a single bevel to a zero edge.
But, there is nothing in katakiri-ha that says there can't be a tiny secondary bevel to strengthen the edge. In most all cases I know of, there IS a minute secondary on the chisel grind. Without it, the edge would not hold up well because the angle will be far too low. In a 3/16" thick blade with a 1" high bevel the edge angle is less than 10 degrees. On a 1/8" thick blade is is 7 degrees.
Most every single edge tol has a micro bevel added. Sometimes it is merely a hand stroke on a extra fine stone at a higher angle. In many cases, the secondary micro-bevel can't be seen without a magnifier. I would not call that a "Classic V grind".
Gravers have the extra "facet" for the same reason ... the edge/point would chip off almost immediately without it.
I would only put the secondary on the main bevel side, not the back. This is because if there is a chip you will have to take the whole back down to flat in the repair. With the secondary on the front, you can do what most folks do and just re-do the secondary until the chip is gone. If the secondary becomes too large eventually due to many sharpenings, then you can take down the entire main bevel to zero again. In all sharpening of chisel edge blades (katakiri-ha), the back is lightly polished to remove any rolls at the edge, but should never be given a secondary. I don't use an exact angle, but I would say the micro-secondary is between 15 and 20 degrees for most kitchen knives.
