Great review Vic...:thumbup:
Unfortunately being in the UK I got mine a few weeks after you guys at Blade got the chance....so my in use photo's and review will have to wait a while longer...
However there are a few full size trees that came down in the making of this...so no expense was spared...
I did some comparison pic's as well with the NMFBM, FBM, the C.S. Khukri, my Hossum Combat/Machete and a Gransfors Small Forest Axe....focusing on "weight" and "performance"....and some aspects on "carrying" these and what is comfortable....
Arising from this I have started making a "shoulder rig" for the KZ...it is nearly finished and should be by the time my time is up...plus with all the photo's it will take a day or so to do the write up...a shoulder holster akin to those for the long barrel S&W N frame revolvers though will vastly improve this as a easy way to support the weight...:thumbup:
On the sharpness front mine arrived "very sharp"....but the width of the convex grind was a bit thick/obtuse for my preference...I guess they had to do this incase some decided that "concrete" blocks were on the "testing agenda"....
Thanks to your "mentoring" I managed to do a job on the thinning process I am very happy with....your tip about using a magic marker to determine where metal was being removed really works well...without going into a review here are some pics of what I mean...
Using these marks and being able to see their removal on the belt sander enabled me to keep a good "even sided" effect...once they were wiped off I just added new ones...keeping the blade cool with emersing it in water in between repeated strokes...got to say this technique is really helpful on these bigger blades....I also practised first to get the movement right on the difficult khukri shape using an old polishing belt which removed no stock...before going to the lower more effective belts....
Personally I found the grips a bit abrasive when using it over extended periods... I am much more of a fan of the fuller hand shaped linen micarta grips which are full and smooth like on my NMFBM...the G10 grips just don't feel as comfortable or tactile for me....so I smoothed down the ridges a little using a triangle sander...
Not removing the pattern....just smoothing off some of the harsher edges...once brushed off and cleaned up you cannot tell the difference to look at but it does make the grip a lot more comfortable for extended chopping...it would have no effect on fitting the knife to a pre-shaped kydex sheath...I was going to order one of these from David but the weight of the khukri indicated straight off that I would need something more substantial than just belt carry...it would be fine on webbing with a shoulder harness or on my molle flak vest...but for civi carry I felt some shoulder bearing weight system would be better...otherwise you would have one side of your pants uncomfortably in need of "hitching up" all the time....
I said right from the start a lighter Khukri would be needed for most people to be able to carry it.... but having gotton mine re-profiled and once the shoulder rig is finished I reckon I am more than happy....this blade does work like an axe... even better in my opinion as it can be used much more effectively all round...it absolutely chops like a "demon"....
