Hey, thanks! I wasn't expecting to get this answered. Good info!
I should also mention that since i used that TBS Boar, i've recommend it to quite a few students in the Bushcraft basic woodsmanship course i help instruct. While to knife guys it seems there are tons of Bushcraft knives and Woodlore clones around, it's not so easy for the average advanced student to find a knife that is a significant step up from a Mora, ( in strength,) especially readily available, and under $200.
I wonder if they'd switch scales so i could get a micarta/carbon steel knife? Hmm....
I love wood scales but the humidity here hates them!
Are they as bad as opinels when they get wet? Do they get harder to open when moisture gets in?
Koster certainly knows how to make an incredible knife. Expensive, but i bet worth every cent. He considers it a frame lock with added scales, so it might be a bit stronger than the others on the lust.That really opened up my eyes! Thanks man! If only that Koster Bushcraft folder was less expensive... seems pretty nice!
Thanks again!
Lastly, the somewhat comparable Spyderco Nilakka. Mixed reports on handle ergos, and a very thin, flat, zero-ground blade.
Spyderco, Nilakka-$200
http://m.spyderco.com/catalog/details.php?product=780
Good luck in your quest, brother.![]()
At the same time, in comparison to those others, you can see the Boar is quite reasonably priced, especially considering exchange rate and E.U. Labor and material costs.
Do a search for reviews of the Nilakka. Reports of edge failure in very light work appear.. e.g.: http://www.bladeforums.com/forums/showthread.php/1000644-WARNING-Pekko-Nilakka-Folder!!!!
Yeah, that's what I've heard. I also heard they eliminated some of this problem by adding a microbevel??
I would definitely agree. I have a feeling I'm going to get one one day... but I'd really like to add a pocket clip.
It's definitely a knife worth saving for! I'm torn o the pocket clip- they're so handy when your not using the knife, but for longer tasks, they can be a real pain. Spyderco's foldover wire clip is probably the most ergonomic I've used. I like that the Enzo's is easily removable and that the scales weren't routed out, so it makes for a smooth, comfortable surface if you prefer not to have it mounted.
