- Jan 24, 2022
https://knifesteelnerds.com/2021/10...ness-edge-retention-and-corrosion-resistance/
I was reading the article above at Knife Steel Nerds and in the article there are several steel rated by toughness, edge retention and corrosion resistance.
In the article there are several images (I won't be putting here because I don't know if I have permission both from the forum and/or the author of the article) and in those images you can see that he rates:
420HC as having toughness as an 9 (I suppose 9 out of 10 was what he meant), edge retention as an 2.5 and corrosion resistance as an 8.
and
1095 as having toughness as an 4.5, edge retention as an 1.5 and corrosion resistance as an 0.
Basically:
So my questions boils down to:
Does that means that 420HC would be better than 1095 for survival knives?
Wouldn't companies like Tops, ESEE and Kabar be better off using 420HC on their fixed blades instead of carbon steels?
Does carbon steels suck? Because it seems so.
The carbon steels seems pretty lousy by that article.
and
Basically:
| Toughness | Edge Retention | Corrosion Resistance | |
| 420HC | 9 | 2.5 | 8 |
| 1095 | 4.5 | 1.5 | 0 |
