but then there is no real definition for stainless either, so bottom line, hard to say.
since free chromium in solution is what contributes to the stain resistance.
There are several chromium carbides, the most notorious of which is Cr23C6. The Cr3C2 version isn’t normally found in stainless knife steels as far as I know.Using the molar % instead of mass % would make it easier to see which steel is more stainless than the other. It is no easy way to accurate explain, as there are also many variation of thing, but I will give my general understanding.
Chromium carbide is Cr(3)C(2) (3 Cr moles for 2 Carbon moles), so the mole amount of Carbon has to be less than 2/3 that of Cr to have some "free" Cr. Then the "free" chromium has to be at a certain amount to a steel to be more stainless, say about 10% give or take molar %, as most of the "stainless" has in common.
The use of other kind of carbide effect the corrosion resistance as well, like:
Molybdenum carbide (MoC, 1 Molybdenum for 1 carbon, or Mo(2)C, 2 Molybdenum for 1 carbon)
Vanadium carbide (VC, 1 vanadium for 1 carbon)
Tungsten carbide (WC, 1 tungsten for 1 carbon)
For the moment, XHP main ingredients are carbon and chrome. It has the same amount of chromium as 440 series, but it is taken by the high amount of carbon. With the low leftover Cr, XHP is no where near near as stainless as many lower chromium steels.
S90V has higher carbon than XHP, nearly twice the carbon mass %, and chromium only at 12% (vs XHP's 17%), yet it is much more rust resistance, because it has a lot of Vanadium.
The molar % of carbon and vanadium in S90V is almost 1 to 1. As most carbon bids to vanadium, the effect of Carbon on the Cr content is less dramatic, therefore a lot of free Cr for rust resistance.
Cru-wear, again, lower chromium, but it has a multitude of heavy carbide former, therefore once again enough "free" Cr to be "semi-stainless".
