Unbreakable
Banned
- Sep 21, 2002
Anyone know a better way to get in touch with Semper Paratus Tactical. I sent them an email and still no reply. Should I go with someone else... are they known for taking a long time? Thanks.
Got a reply back... Here is another question... He said he has a FBM in shop with Magnum handles and he could make the sheath from that. Mine have standard handles... Correct me if I'm wrong but the Standard handles are thinner yes? So if he made one based on a FBM With magnum scales.... my knife would fit in it it would just be a little loose in the neck where it engages the handles right? Which is fine by me since it has the handle strap. How much thicker are the magnums compared to the standard? Shouldn't make too much difference right?
He is making one for me at the moment for my FBM with standard handles.
He said he had a knife to work off of for me. I imagine he either has, or has access to, each.
I placed my order AROUND three weeks ago, though I'm not 100% sure. I know my credit card got charged today. I shot him an e-mail, but haven't heard back. I also know that at that time, he said he had a knife on hand that he coud use, when I told him I had standard handles coming. I do hope that it is a standard that was used.
I just left a voicemail and will let you all know.
What would be the biggest problem with getting a sheath made for Magnum scales when my knife is standard. I mean if it's a little loose I don't care... I actually don't want the knife to lock in and require a lot of force to pull out. If it were a little loose I wouldn't mind... let me know as I'm pretty sure I'm going to go ahead and order it unless there is the possibility that it will just simply not fit. Loose is ok... too tight would be a problem. Appreciate the help guys.
The fit into the sheath would probably be OK...it is the fit of the snapped nylon strap that holds the knife in the sheath that would be too loose if based on a magnum handle for a standard handle.
