- Feb 24, 2000
Those of you who have experience with 3V or M4, how finished is the blade when you heat treat?
I make a lot of knives of CPM154. I completely finish grinding the blade, then hand sand with 400 grit and then send off to Bos heat treating. When I get the blades back I re- hand sand with 400 grit and go up to around 1200 grit. I don't go back to the grinder after heat treatment. When I send the blades off, they are finished except for the hand sanding.
Can you do that with 3V or M4?
Looking at Peters site it says air hardening steel should be no thinner than 0.015. That is close to how thin the edge on my CPM154 are when I send them to Bos heat treating.
So, will that work with 3V or M4? From my point of view the more I can do before heat treat while the steel is in the annealed state, the less I need to do once the steel is hardened.
