- Feb 23, 2002
I'm sending my leatherman wave back for repairs along with a copy of this letter.
To whom it may concern,
I have enjoyed using my leatherman wave for a couple years now. I use it daily for a number of things.
I'm sending it to you to have a few repairs made. The joint on the needle nose has alot of play in it. There is alot of play in it when it is open and even more when it is folded up and in the leather sheath. There is so much play in it when it's folded up that it rattles in the sheath on my side well walking around.
One of the first times I used the wave to remove a house door hing pin the fine tip on one of the needle nose broke off. Shortly after that the other one broke off. I filed the tips of the needle nose even so I could still us it. If you think the tips should be replaced please do so.
I also have trouble removing the tools from the side of the handle that has the phillips screwdriver in it. All the tools in that handle are very tight making them hard to get out. Could you please loosen them up.
As you can see I use the knife blades alot. They have been resharpened hundreds of times. Could you please replace both blades.
The file you have put on the wave is great! I also use the file alot and have found it to hold up very well. Thats one great file!
Please look over the wave to see if there is anything else that should be repaired.
I'm in the appliance repair and refrigeration field and alot of different people see me using the leatherman wave daily.
Alot of them ask me "what kind of multi-tool is that". Once I tell them its a leatherman wave there nexted question is always "how do you like it?"
Well guess what I tell them
Sincerely,
Name:
Address:
Phone Number:
Bladeforums.com member: pahl
Do you think leatherman will repair or replace the wave?
How long do you think it will take them?
Anything you would change in the letter I'm sending along with the tool?
Thanks for your input.
pahl
Sincerely,
Name:
Address:
Phone Number:
pahl
