Sentry Solutions Bore Products
I am reposting my review from TFL here. Apologies to Dexter, Spark, Mike and all non-gunnies that it's not knife related. If this causes a problem, feel free to lock or delete at will.
Background:
Kevin Mad Dog McClung of Mad Dog Knives has done it again. For those who may not know it, Kevin is not just a scientist and premier knife maker, but a highly qualified gunsmith in his own right.
Mad Dog is currently putting together a specialized .308 hunting rifle for me...much more on that later. In discussing barrel break-in, Kevin made a strong pitch for Sentry Solutions' products. Seeing as how Kevin is not easily impressed by products (or people
), when he recommends something, it's worth looking into.
Review:
Sentry produces two specific products for bores: Smooth-Kote and BP2000 Powder. Both are based on solid lubricant and dry film technologies beyond my limited comprehension. Essentially, the products create a dry, layered crystal coating that is intended to create a nonstick surface.
Smooth-Kote is a dry lubricant suspended in an alcohol carrier. When the alcohol evaporates it leaves a dry molecular coating in a pre-cleaned and degreased barrel. The product takes a bit of work to use, as the barrel must be completely clean and heated with a hair dryer. That done, Smooth-Kote is claimed to *replace* gun oils and barrel treatments.
BP2000 Powder is a black, graphite looking dry powder that is used to "fine tune" the lubrication process. The powder is applied to a tight fitting patch, wrapped to a jag and used to "burnish" the barrel interior with 40 or 50 strokes.
Upon application of the two products, the manufacturer claims that the bore may be maintained by a few strokes of a *dry* nylon brush and touch up with the (original saved) BP impregnated patch. Bore cleaners are not recommended as they will actually remove the dry lubricant requiring the entire process to be repeated.
I recently used these two products to treat a new-in-box Ruger Model 77/22. As most know, nothing fouls a barrel worse than .22 rimfire lead bullets. Over the past week, I have run 1,000 rounds of nonjacketed .22LR thru the gun. I used the nylon brush method 3 times: 3 or four passes with the brush; one pass with a clean patch; 4-5 passes with the BP2000 patch.
I failed to find a glimmer of lead on the clean patches....they continued to come out coated with the BP2000 powder and some normal powder fouling. A bore light revealed no trace of fouling after the "cleaning" process.
Being charitable and cautious, I subjected the barrel to the Outers Electrochemical system, using Outer's Lead Removal solution. I first ran an alcohol soaked patch thru the barrel to remove the Sentry Solutions' products. The Outer's system failed miserably to find any trace of lead in the barrel and showed it "clean" within about 10 minutes.
Tests will continue, but I think these products may be the ultimate bore conditioner for new and used rifles...clearly, the lack of lead would indicate less friction, higher velocity, lower heat and extended barrel life.
Mad Dog Knives may be viewed and ordered at http://www.mdenterprise.com/
For more on Sentry Solutions products try http://www.sentrysolutions.com/ .
Sentry Solutions products may be purchased from our sister site at http://www.bladeforums.com
Rich Lucibella
I have had the Sentry Solutions "dry lube" treatment applied to my S&W 686 Plus by Ricky Devoid of Tarnhelm Inc. After shooting 50+ rounds of .357 mag ammo during one session, a dry patch was run through the barrel and cylinder. The patch was still very clean. This makes shooting all pleasure without the chore of cleaning. I like it so much that I plan to have any future gun purchases treated the same way. The cost of having it applied is not cheap ($80 to $110), but it will last for thousands of rounds with occasional touch ups.
Axel
Axel; what are you talking about? I know the Sentry line of products fairly well, and can't think of one that would need to be applied by a professional. If you know of such a product, please clue me in.
Discount Knives, BTW, has a Sentry Armorer's Kit, which includes a Tuf-Cloth, Tuf-Glide, Smooth Kote (including a refill bottle), and the BP 2000 powder. Further included are complete instructions, gloves and applicators. For $30, it is a bargain.
I have yet to try the products yet, except for the Tuf-Cloth and Tuf-Glide, but will be treating the bore of my 1911's with Smooth-Kote, and let you know what happens.
BTW, Rich, you don't NEED to use a hairdryer to cure the Smooth-Kote. It will dry at room temp in 2 hours. Using a hairdryer will speed up the process however.
Stay slick, Walt
Further, it clearly states on the instructions that Smooth-Kote is NOT a permanent coating. From what I have read, however, it stays on for quite some time.
Hope this helps, Walt
Walt-
The instructions for Smooth-Kote indicate hair dryer or overnight in a warm place. Perhaps 2 hours would do.
I'm aware that it is not a permanent coating. As cleaning products will remove it immediately, I assume that you should leave it as is, with touchup, until fouling begins to occur. Then retreat.
Rich
Axel-
Apologies if I'm butting in.
If they're using the Sentry Solutions products, they're referring to the process described in my review. To perform the "full" ($110) job, is about 1.5 hours work, first time around....it's not particularly technical.
Whether it's worth the price depends on your priorities. I could save a great deal by reloading...I just don't enjoy it anymore, so I pay the extra $$$. Regarding the Sentry Solutions system, I'd prefer to do it myself.
Rich
[This message has been edited by Rich (edited 01 April 1999).]
