- Aug 24, 1999
Hi All,
I'm about to make the "jump" from tactical folders to tactical fixed blades and I have some SERIOUS concerns about sheath options...
Ok, here's my main concern...I read somewhere that you should never use an IWB sheath IF you are (ahem) a "big" person and your stomach hangs over your beltline because you may cut yourself as you withdraw...well, let's just say that I qualify for this concern! So, is this something I should legitimately worry about? Will I encounter the same problem with a "high-ride" strong side sheath? What about crossdraw? (yikes! I imagine that would be even worse!)...What about a "dundee rig" type sheath...will I slice my a$$ off if I try to withdraw quickly and I am not standing exactly straight?? SOB??
Ideally, I would like a sheath that allows me to withdraw (with great speed) into reverse-grip (blade out)...also, I am seriously considering a double-edged blade (or should I not even think about that??).
Thanks,
RL
Thanks,
RL
