yablanowitz
Platinum Member
- Apr 14, 2006
As far as I can see, it will suffer from the same problem as any other draw-through sharpener. The abrasive will cut microscopic (or larger) grooves in the edge bevel parallel to the edge. These grooves will act as stress risers, weakening the edge. Think of a piece of corrugated sheet metal (barn metal). If you place it with the edge on the ground with the grooves running parallel to the ground and push down, it buckles. If you place it with the edge on the ground and the grooves running perpendicular to the ground and push down, it will push into the ground. the ribs (grooves) add strength to the metal one way and not the other.
Sharpeners like the Sharpmaker cut microgrooves that are perpendicular to the edge. Not only do they act as micro serrations, they even add a little strength to the edge. Not as much as the ribs on corrugated metal do, but certainly more than the parallel grooves left by a draw-through.
