I have one serrated blade, Spydie Pac Salt. I work with a lot of rubber tubing and soft rubber pipe insulation. Nothing cuts both like a serrated edge. Plain edge, no matter how sharp, has trouble starting the cut.
The only time I carry it is at work.....EDC is always PE.
I keep the serrations up with a small diamond rod. Works very well as H1 is pretty soft.
Joe
I found that if you pierce it with the tip first (in order to propagate the initial crack), it's then easy to slice through things like garden hoses, irrigation line, and rubber tubes, with a non-serrated edge.
