serrations
I am going to try to make a knife with serrations. I have made some in the past without serrations and they came out well. My question is do I cut in the serrations before or after heat treat?
Regards,
Glenn
Glenn,
Make the serrations before the heat treat. Afterward the blade is too hard. Use a round file, and with the blade edge facing you in a vise, push twords the blade edge going only in one direction.Make sure that you keep the same angle for all of the cuts you make with the file.You can vary the size of the serrations by varying the sizees of the files you use.
