Why do makers always put them by the handle? I normally cut with the front half of the blade and use the back half for carving so if serrations were opposite wouldn't it be much more useful? With that being said why haven't I seen any like this?
I've been argueing this for decades, to no avail.
It would, if nothing else, absolutely improve a knife intended for fighting (especially compared to almost all factory plain edge geometries), since the forward part must first get under the clothing, or "grab" for cuts without pushing: Instead we get plain edges that start out poor near the handle, and, as they go forward towards the point, and round the edge belly, they then open up into the truly pathetic... The plain edge angle opens up, and you go from a sad 40 degrees inclusive near the handle to a mind-numbing 60 degrees inclusive as the curve is rounded...: Even the bigger Chris Reeve One piece range follows this pattern to a T: Full re-grind needed, with great care to not deform the point too much, and the edge is borderline too thick at 0.040" behind the edge to begin with.... You can imagine how well many cheaper knives do...
The notion of the serrations "starting" the cut sounds nice, but it has only a very crude and unreliable bearing on reality...: Most serrations
have their peaks not lined up with the plain edge: So the "started" cut will bite, and then your plain edge takes over and starts another slice
besides the original serrated cut... That is why it is better to choose a fully serrated blade, because at least then all the cutting is done on the same plane...
The inanity of partial serrations near the handle, especially the way they are done right now, just shows how assumptions as to what works have far more clout than real-life observations about how things actually work...: The reality is partial serrations ruin what on most knives is the BEST part of the edge (and that needs serrations the least, having the best available leverage), and they then leave intact only the part of the plain edge that is always the WORST, and has the least leverage...
Sad but true.
Gaston
