- May 18, 2005
I wonder if you guys see these the way I do ? Only a few of my knives have any serrations on the blade, and under most circumstances I'm glad of it. I find that in my normal, everyday, cutting jobs the serrations are far too aggressive and simply "grab" at the material to be cut rather than actually cutting it. The only exception to this is the serrated blade on my Swisstool. This has a far less "toothy" look to it, more like a scalloped edge than truly serrated, and this cuts like the devil. Ordinarily I find that a properly sharpened plain edge is the best tool for the job. I realise that serrations can be of an advantage for tasks such as cutting relatively loose fibrous stuff like thick rope, but the teeth of the serrations are all too often just too pointed to do anything but grab when I try to use them. In fact, about the only time I use the serratons is to cut packing case banding with a direct pressure cut rather than a slicing action.
How many of you find that you use the serrations on your blades in preference to the plain edge, and what do you use them for ?
