I have a set screw that is stuck deep in a 6 inch aluminum drive wheel. It is a solid drive wheel so the set screw is an inch and a half down in the hole (at the bottom). The hole is too small and too deep to get an extractor into. Ive been trying to drill through it with a long bit so I can drive something into it but Ive hit a hard spot and the bits are just rounding over. No carbide bits that long in my area.
I was thinking to just give up on it and drill/tap a new hole but the set screw is actually sticking down a bit into the keyway, and would interfere with the shaft, so that is out.
Im seriously considering finding an acid that will eat the steel but not the aluminum.
Any ideas and pity will be appreciated
Thanks
Robert
Thanks
Robert
