There's a big difference between setting an edge and sharpening an edge on the grinder.
You did mean setting it right Joe?
I flat grind my forged blades down to 0.005- 0.010" at the edge (this is a combination of belt and 9" disc work).
Once that thin, I either gently rock the blade out on the disc, or use the rotary platen and take it down close to a cutting edge.
Then I go to my stones, sharpen, and test. If I'm happy, I dull it by pulling the edge against the stone a few passes, then go on to my hand-finishing.
Personally I don't like using a slack belt to set the edge or sharpen, as it tends to roll out at the choil and tip... which causes a funny little dip at the choil and usually a lost tip.
The sharpest knives I've ever made are the scandi grinds where I actually grind to a zero edge (and get the wire started) with a 220X belt, and then strop the burr off on cardboard. It's kind of like a laser but without the cool colors.
Edited to add that since I realize like 70% of the makers out there use a belt to sharpen, don't get your panties all wadded up... I'm not saying it's wrong, it's just not what I prefer. When you take your edges down as thin as I do, it's way too easy to ruin the blade on a slack belt.
