- Apr 1, 2007
Man, it sure is going to be nice using my new belt grinder, IF I can set it up right. It's a Coote with 10" wheel.
I hooked it up with a 3" pulley on a 1 HP AG motor, 1725 RPM. The grinder got a step pulley of 4", 5", and 6".
My calculations show SFM speed of 3364, 2691, and 2242 speeds respectively.
Now, it this in the ballpark for common grits of 2" X 72" that you guys use?
(Never used a belt grinder before).
Also, I like a pretty deep hollow grind on most of my working knives (skinners). Some also get a fuller with two seperate hollows.
Before, I rough ground them out on a 6" bench grinder, and cleaned them up with a die grinder and some jigs. Took a long time, though.
Question: Can I do this work on the 10" wheel of the Coote? Or maybe it's time to build a forge:jerkit:
Thanks,
Mike
Thanks,
Mike
