Photos Several Questions About a Sykco
Hello everyone, I've been paying attention to a Sykco recently, but since people label it with different names every time I see it, I'm not sure if it's the same knife.
So I have a few questions:
1. Are they the same knife?
2. What is its exact name?
3. What is the meaning of the number on one of the knife blades?
I used someone else’s picture — hope that’s okay.
The numbered blade is either a Test Team version or there may have been a MO version. None the less in general terms the knife is a Regulator (noting there are different blades pictured). There are a few versions of this over the years but the crinkle coated all black un-numbered blade is a “Regulator”. There are exact same knife with the top bit of the ResC grip that forms the top “guard” removed is a De-Regulator. There are a couple of camo (a desert and jungle version) variants as well as the later (recollection is telling me hollow ground) version that has a parkerised finish.
Welcome to the wonderful world of Busse where it is always best to never say never… ;)
带编号的刀刃可能是测试团队版本,也可能是军事行动部门(MO)版本。无论如何,总的来说,这把刀是一把调节器(Regulator)(注意图片中展示了不同的刀刃)。多年来,这款刀有几个版本,但带有皱纹涂层的全黑无编号刀刃是“调节器”。还有一种完全相同的刀,去掉ResC握柄顶部的“护手”部分,就成了“解除调节器”(De-Regulator)。此外,还有几种迷彩版本(沙漠迷彩和丛林迷彩),以及后期(我记得是凹磨刀刃)采用磷化处理的版本。
欢迎来到布塞的奇妙世界,在这里,永远不要说“绝不”……;)
Thank you very much for your answer, but I feel that they are all Bowie knife types — is that the reason for my confusion?
The varieties of the regulator I'm aware of:
Military Regulator = Flat (or slightly convex it seems on mine) Saber Grind
American Regulator = Full Flat Grind
Urban Regulator = Hollow Saber Grind
DeRegulator = Top finger guard removed, this was a factory option on some models.
我所了解的调节器种类有:
军用调节器 = 平刃(或者我的这把刀刃看起来略微凸起)
美国调节器 = 全平磨
城市监管者 = 空心剑磨
解除调节器 = 移除顶部手指保护装置,这是某些型号的工厂选配功能。 兄弟
thanks bro
…….all are a “Bowie” type blade shape but the SYKCO model is “Regulator”. In the Reg series the blade grind, length and finish may vary (and still be a Regulator) as well as some colour differences in the ResC grips (Black/Tan/Green options).
……所有刀具的刀刃形状均为“博伊刀”型,但SYKCO型号为“Regulator”。Reg系列刀具的刀刃研磨方式、长度和表面处理可能有所不同(但仍属于Regulator系列),ResC握把的颜色也略有差异(黑色/棕褐色/绿色可选)。
oh,i see!
