First impressions of the pair I just recieved.
The USPS Priority box was clean & undamaged,
The usual heavy newspaper wrapping on the blades,
but both scabbards were dented.
More on that at the end.
Anyone else have damage?
As soon as I saw these I was impressed.
They look -much- better in person than the pictures.
The scabbard is -very- well made.
A sturdy white-metal (non-magnetic)
that has very pleasing & well-executed
stamped "engraved" lines making the design.
Very clean construction.
Red Velvet looks fine,
although If it were red leather I'd say I preferred it.
The blades & handles are as nice as usual,
with maybe an extra touch or two of care.
Again white-metal fittings.
They are very close in dimensions,
but not exactly the same.
They fit somewhat tightly in the scabbards,
although they just got in from the cold
& might loosen. ???
Scabbard #1 damage:
Worse of the pair.
Longish 'punch' type dent in the flower in front.
The back 'shell' has a similar dent in about the center,
And worse, a dent in the upper edge of the collar & top.
This last dent was angled up & pushes in
on the top surface behind the blade entry.
The collar to the side of this is bulged out.
Scabbard #2 damage:
Only a small dent on the back shell center similar to the first.
This damage is surprising since the metal is sturdy enough
to require some force exerted to dent it.
I could not with my hands squeezing
unless I had something hard to push with.
Frankly, it looks like someone used one
(or something else hard) to hammer on the other.
Or maybe banged the scabbards on the edge of something hard.
It does not look like they were stepped on.
Fortunately,
the retaining band in the midle seems loose enough
to slide off and allow disassembly.
I can probably push out most of the dents and bends
with a round tip dowel.
