- Sep 27, 2004
Hello,
When constructing a shadow pattern slipjoint with a bushing pivot, do I really need to add a washer to peen the pivot pin into, or can I just peen the pin directly into the scales?
The washer construction looks like a traditional sodbuster, where a 1/4" or so washer is put into the scales, then the pin is peened into that.
The way I see it, if I am using a bushing, the liners themselves squish the bushing and the blade revolves around the bushing. This should mean that hardly any pressure is exerted on the pivot pin itself.
I made a shadow construction just peening the pin directly into the scales without a washer and it had held up just fine....
Is the washer construction really necessary or is it just tradition? I assumed it was done mainly to allow stronger peening of the pin and to avoid cracking the scales since theres no bolster to peen into....
Any thoughts here?
For reference, this is the washer construction I am talking about:
Any thoughts here?
