nozh2002
BANNED
- Jun 9, 2003
This idea come from Ivan Kirpichev in discussion on guns.ru about damascus advantages and disadvantages. He point out that even when damscus does not create really microsaw itself - this saw should be as big as damascus pattern, but however same microsaw in layered steel will looks different then on normal blade.
I tryed to draw picture to demonstrate his idea.
Edge on normal blade after sharpening:
Edge on layered blade with hard and soft steels after sharpening:
Edge on layered blade some use when softer steel went away because it is softer:
As you may see idea is that layers will create different microsaw - Sharp Jaw like microsaw, which may cut different then normal monosteel edge.
Of course this is just hypothesis - what do you think?
Thanks, Vassili.
Thanks, Vassili.
