Well that's very nice you like yours. I HATE mine so I guess that makes us even.
What a piece of crap. :thumbdn:
Ifilef: the Sharpmaker is nothing more than thin benchstones lifted from a normally horizontal position to a few degrees from vertical. It is, without a doubt, your technique that is faulty. I mean that constructively.
With that said, the Sharpmaker does have a few limitations that make it less than ideal:
- it only has slots for 15 degree and 20 degree (30 and 40, inclusive) angles;
- the medium rods are not coarse enough (approximately 600 grit);
- the coarse diamond rods needed to do what the medium rods will not will set you back about $65 or more, I think.
For those advocating the purity of benchstones, well, I admire them and their skill, BUT - in reality, that's precisely what the Sharpmaker is: an inverted benchstone. Imagine you're in your shop. Your favorite benchstone (Arkansas, diamond, ceramic, whatever) is on the bench. You're bending down trying to look
under the knife blade...between blade and stone....trying to get an idea how close you are to the angle you want. You lift the stone from one end, the other end stays on the bench, and you peer down between stone and blade. You just gave birth to a Sharpmaker.
Try the sharpie marker technique that others have said. I use it all the time. There are ways to
rebevel (NOT "reprofile") the edge to say, 12.5 degrees (25 inclusive), that will enable you to use the 30 degree setting just for adding a micro-bevel. You can do this without buying the diamond stones by using wet/dry (120 grit through about 320 or 400) clipped to the stones. Like someone else said, most ALL factory knives come with too obtuse a bevel for the Sharpmaker, let alone for my tastes.
I'd recommend you don;t give up on your sharpmaker - just work on technique. At a minimum cost of $45, it's too expensive a tool (and too
good of a tool) to dismiss without understanding it.
