You should just buy a metal cutting bandsaw.
Not always a viable option due to spatial constraints, living quarters or financial needs. If one is going full time, sure, but speaking for myself I just can't swing a metal cutting bandsaw in the near future.
How about having somebody cut out a good supply of blanks. Great Lakes Waterjet would be happy to do that, or another maker with a saw.
If I had to cut out my blanks with a dremel and a hack saw I would find another hobby.
Thanks for all your suggestions guys. I cut out 2 blanks today using the drill and dremel method. I may have someone cut them out for me in the future.
Jon"Petie"Ross
You can turn a hand held belt sander upside down in a vice, or clamp to the bench. Don't run the sander for a long time continuously, though. I burned one up one time, but it was running for nearly an hour straight. I've seen some really beautiful knives that were made with a hand belt sander. The belt heat up quickly, so you can't bear down on them, or you'll loose all the grit.
You can also get a sanding wheel for your drill. I think they take 5 or 6 inch sand paper disks, or you can use sand paper and spray adhesive. This is probably easier than an angle grinder and not so loud. It also prevents you from making booboos like with an angle grinder. If you want to use an angle grinder, consider stacked sandpaper wheels. I really like using them because they take material off at a slower rate than a hard disk.
Good luck,
BJ
