- Jan 2, 2011
Or, put it all together with some other solid pins and a drop of superglue. Do all your shaping. Knock out the sacrificial pins and bust the superglue loose. Chamfer your holes on your already-contoured handle. Then glue up the knife with your tube stock and epoxy. When it's cured, grind the tube down flush, then flare it.
Not a bad thought.... I am leaning more to the waxing the living hell out of the tubes, epoxy everything together. Remove the tubes after the expoy has set up some. Countersink the holes, and then shape. Epoxy the tubes back in and then flare.
Looking forward to see KalEl's thread.
-Brian-
