- Feb 22, 2007
hello,
in my opinion the blade geometry has a lot to do with the cutting capability, but only in cutting throught materials, because a blade too thick will wedge into the material instead of cleanly going throught it.
BUT... in push cutting paper I think It's only a matter of pure sharpness, for example my endura 4 saber grind finished with 6000 grit and strop cuts print and phonebook paper like mad, much better than a boker barlow finished with the ceramic side of a fallkniven dc4. However the Endura hasn't got any chance with an apple against the full flat grind less than 2mm thick blade of the barlow.
I've seen a gransfors&brooks axe push cut print paper with no effort in a ray mears video.
regards, Lute
I use a kalamazoo 1SM to sharpen my axes, choppers, machetes, large fixed blades, lawn mower blades...etc.
It is easy to get any of the above to push cut newspaper. It really doesn't matter how thick the blade geometry is.
Here is a quick video of a thick thick chopper cutting thin hanging newspaper.
[video=youtube;umlkJh65pus]http://www.youtube.com/watch?v=umlkJh65pus[/video]
My GB splitting axes will do the same. Even cheap machetes and hardware store axes can be brought to this level easily.
With that said it shows how an edge is finished is key to sharpness. However, geometry still cuts.
It is my opinion that Opinels/peanuts are known for 'off the stone sharpness' for a couple reasons.
First the blade profile is so thin there is not much of an edge bevel. Therefore it takes little skill to make consistent contact with the cutting edge during honing.
Second, most people do not cut paper day to day, and like you said, when material separation comes into play, so does edge geometry.
